Reply
Highlighted
Occasional Contributor
Re: Weird "artifact" in 70D photos.
Thanks guys. I'll look at getting the shutter replaced. It definitely won't be as expensive as replacing the camera.
Highlighted
So, to test the theory, I decided to try something. This probably isn't any breakthrough for you guys, but I found it rather clever on my part (not knowing enough about the inner workings of the DSLR). I turned the mirror lock up to on, hit the shutter button to lock the mirror up, then gently held the mirror up while firing the shutter. I filmed it with my Samsung Note 4 doing slow motion. You can clearly see the shutter problem.
I'm assuming this is the failing shutter, but I'll take any expert opinions here:
Highlighted
The sad thing is I only have 67,862 actuations on my shutter.
Highlighted
Respected Contributor
Yep, shutter failure.
Highlighted
Honored Contributor
I think that machination falls in the "Don't try this at home" category. I can understand why you wanted to test the "theory", but every time you stick your fingers into the lens opening, you risk breaking something or, at a minimum, getting it dirty. Any broken shutter is a loose cannon (unintended pun!). and when you manipulate it, you risk scratching the sensor. You probably got away with it this time, and Canon will clean it up for you as part of the repair. (The Jamesburg shop, just to name one with which I'm familiar, does an amazing job.) But I wouldn't try something like that again.
Bob
Highlighted
I agree this is the second user that posted that they physically held up the mirror in their camera. This is a bad idea, that is more likely to cause more harm than good.
Highlighted
Esteemed Contributor
[ Edited ]
Especially since mirror lock up will do exactly what they want.
(Though I am not about to see if it works with the lens off...)
powered by Lithium
