Reply
New Contributor
Vertical line on all jpeg images
hi guys,
From yestarday I have issue with my new Canon 5D Mark IV, on all jpeg images I see vertical line in the midle of frame. I don't see this line on RAW images. This line can be seen on camera display when I review captured image and the same line I can see when I'm using external programm for viewing/editing image.
Please help me to recognize what can be reason for this line.
Regards,
Oleg
Honored Contributor
Re: Vertical line on all jpeg images
Start by making sure that your 5D4 has the latest firmware. I bought a new one last week, and it was at least two revisions behind.
Do the lines appear on JPEGs taken with the camera or on JPEGs converted from RAW files (that don't have the problem)? If the latter, what program is doing the RAW conversion?
Bob
VIP
Post a sample photo.  Smiley Frustrated
"I don't see this line on RAW images"
You can't see or view a Raw photo at all. Not possible. It has to be processed into some other format like a jpg.
"I'm using external programm for viewing/editing image."
This leads me to believe it is something happening when you convert the image. Look at whatever "external programm for viewing/editing" you are using. It is faulty.
New Contributor
[ Edited ]
hi Bob, thank you for replay. This line firstly was appeared, when I captured video on this camera and now it on each image or video.
The one vertical line appears on JPEGs taken with the camera and I can see this line on camera's screen when using life view mode.
Regarding Firmware version you are right. On camera I see version 1.0.4 and on Canon site 1.1.2. Do you think this firmware software issue?
Best Regards,
Oleg
New Contributor
Thank you for reply. The first month camera worked perfect, but from yestarday this vertical line. I see it on camera display when just prepare to capture (in life view mode).
The same on video and on image.
Tried to clean sensor, not help. What to do?
Best Regards,
Oleg
VIP
"Tried to clean sensor, not help"
It is not a dirty sensor as you found out.   I doubt it is a FW issue either but I would do the update.
It could very well be a bad sensor and I think a call to Canon support is in order.
VIP
A line created by a defective LCD or sensor will be sharply defined, often only one pixel wide.  A line created by a bright light which overloads the sensor (called "blooming") will be many pixels wide and will go away when the camera is pointed away from the light. Flare, caused by a bright light striking the lens, even outside the field of view, will be wide, fairly diffuse and also go away when the light no longer strikes the lens.
Esteemed Contributor
That’s not normal. Contact Canon service. You’ll probably need to send it in for warranty service.
Tim Campbell
5D III, 5D IV, 60Da
Honored Contributor
Best Regards,
Oleg
I doubt it, but that is something they may ask you when you call Canon Support. Actually, I'd be inclined not to update the firmware, just to keep things as much like they were when the problem arose. But I do think you have to call Canon Support; that's not something that can simply be ignored. My guess is that it will require a warranty repair.
I assume you've tried a different card? It doesn't really look like a card error, but I suppose it's a possibility that needs to be ruled out.
Bob
New Contributor
I have been in garanty center and they sayed me that corrupted matrix. Cureuption can be done by laser when camera captured video. Do you know how can be much matrix for mark iv?
powered by Lithium
