04-24-2020 01:30 PM - edited 04-24-2020 01:35 PM
I have Windows 10 on pc and use Canon DPP .When connecting the camera I wish to by-pass Windows Photos uploader, which automatically uploads pictures, and allow DPP only to upload any pictures? Any help much appreciated.
04-24-2020 02:50 PM
DPP isn't really designed to do that. I always use a piece of free software called "Digital Image Mover" it has a lot of advantages and is far more versatile than Microsofts offering. A google search will find it.
04-24-2020 05:42 PM
You can use Canon EOS Utility to download photos from camera.
04-24-2020 06:14 PM
I have been using EOS utility for file transfer since buying my first 1 series back in 2005 and it is an easy system to use that works well. File transfer is very fast with most bodies and it is the way I have been working with the EOS series for over a decade.
The only issue I have run into is with some of the goofy Windows 10 updates that have forced me to reconfigure the ethernet settings (I use the 1 series ethernet ports for transfer rather than USB) but that is a problem due to the very problematic and unstable Win 10 operating system that screws up a multitude of new things with every update, NOT an EOS utility issue.
Rodger
04-24-2020 06:53 PM
@wq9nsc wrote:I have been using EOS utility for file transfer since buying my first 1 series back in 2005 and it is an easy system to use that works well. File transfer is very fast with most bodies and it is the way I have been working with the EOS series for over a decade.
Rodger
I like using DPP for file transfers, too. I especially like being able to create custom file and folder names during the download. I can "pre-sort" files before I import them into the Adobe LR/PS environment. I like LR because I can apply various types of masks, something which Canon's DPP lacks.
04-25-2020 11:04 AM
"I have Windows 10 on pc and use Canon DPP..."
Not directly your asked for answer but Lightroom is so much better than DPP4, I would suggest you give it a try. Its import flexibility and presets are well worth it. It can be set-up to improt when you connect the camera to the computer without input from you. Any and all preset settings, or none, your choice, will be applied automatically. Once imported, LR's editing controls are far above what DPP4 can do.
04-25-2020 03:25 PM
