Reply
VIP
Re: Canon 6D turns itself off after a few shots with fully charged battery - amazing Canon service
Your video shows a malfunction all right. But I am sure the Canon engineers are not seeing the same thing.
I think we can agree on this?
So what is different? That is what we must figure out.
You did send your batteries and charger it Canon with the camera?
With no further evidence than I saw in your video, I would say bad battery and/or charger. A nearly drained battery will act just like that. There is enough charge left in it to operate the camera for a few seconds or minutes.
Occasional Contributor
[ Edited ]
I did send in my battery, and my charger last time (not this time).
Since this is the second battery, and manufactured in different year from the previous one, I doubt it is a battery issue. The charger may be the suspect though, I agree. But I measured the battery with a multimeter after a fresh charge, 8.23V, so it seems the charger at least worked.
What puzzles me even more is the battery info showing 92% power left. If this is an empty battery then, the camera is not reading correctly either. I was able to reproduce once or twice after this video before I sent it in, took roughly 40 actuation each time. Then the camera arrived at Canon facility with remaining battery power, and then the issue simply disappeared.
- edit: I did  a quick google,
http://www.p4pictures.com/2012/12/eos-6d-battery-life-with-wifi-gps/
It says a single charge lasted around 3000 pics. This is pretty consistent with the 92% and 230 pics showing in my video.
VIP
"But I measured the battery with a multimeter after a fresh charge, 8.23V, ..."
This actually does not tell you the state of the battery. You must put a load on a battery in order to test it.
I hate to sound like a broken record but it really sounds like a bad or discharged or undercharged battery. Whether it is the battery or the charger is unknown.
Respected Contributor
[ Edited ]
Wow...after watching the video...I don't know what to say...you were able to reproduce it so easily so many times...It is unfathomable that the Canon guys couldn't reproduce it at all.  Were they even trying?
Have you tried asking for a replacement?  This problem would make the camera unuseable to me.  Instead of trying to fix it, you need to get a new one.  Try demanding it.  They have lemon laws for cars, there ought to be one for cameras too.  Canon can keep the offending camera and play with it more but you can't afford not to have one for too long.
Regarding the problem, it's obvious to me that the battery voltage/current detection circuitry is the offending one, if you can rule out the batteries.
Regarding the batteries, I must relate a story which is true and it happened to my sister in law - it's still ongoing sort of.  She recently bought a brand new Lexus Sedan and two weeks out of the dealer, the battery went dead after a couple of days without driving.  Battery was charged and a few days later, battery went dead...The car went back to the dealer and they told her 1. She left her lights on then 2. she didn't know how to drive properly so the car failed to charge then 3. She needs to unplug the battery when parking more than 2 days - they even showed her the installation manual (which outlines the deep storage procedure).  This went on for several months and the dealer couldn't duplicate the problem or refusing to try very hard.  After being threatened with returning the car using the lemon law, they kept replacing the battery but after the third new battery, amazingly enough, the problem hasn't shown up for a month now...What is the chance of 3 brand new batteries were bad back to back? But this happened to my sister in law.  I agree with ebiggs...the battery voltage curve versus capacity is very weird...it will show a full plateau with a cliff at very low capacity end. Let's say if the cliff is at 25%.  What this means is if you check the voltage, it will show you 90% full  even at 26% capacity then when it hits the cliff at 25%, it'll show you close to zero.   The camera battery indication, I guess is interpolated so the effect is not so obvious.  But for a defective battery, it can fool the camera easily to show what you saw.
Canon should at least give you new batteries to try.  I just hope Canon, unlike Lexus, would believe its customer instead of accusing them not knowing what they are doing.  My sister in law would never buy another Lexus for as long as she lives now. It's sad - good car...very bad batteries.
I don't doubt you have checked everything but just in case, I'd inpect with a flashlight the camera battery compartment leads to make sure they weren't partially covered by protective plastics.  If you know someone that you can borrow more batteries and even better a battery grip and see if you still would have the problem.  The grip would be a good debugging tool since the battery leads are separate from the regular battery.  If you still have the problem then you can rule out the leads...the circuitry is the remaining culprit.
Diverhank's photos on Flickr
VIP
"Instead of trying to fix it, you need to get a new one."
They are not going to replace the camera if there is nothing wrong with it. There would be no point. Now replacing  the batteries or charger, OK, I agree.
I can't imagine Canon is not trying and testing it to the fullest. Maybe I am wrong but I really doubt it. Especially with the dealings I have had with them. I don't know what the problem is but I am still going with a faulty battery and/or charger.
[ Edited ]
At least the OP would be able to rule out the camera.  I'm agreeing with you that it's a battery/charger issue but you will never know.  Must give the OP the benefit of the doubt.  I would definitely try a battery grip to rule it out.
Come to think of it, I personally had similar occurrence  that happened with my Canon 50D, freshly charged battery would go dead within minutes.  In my case I quickly found the culprit which was the charger.  It would lie to me that the battery is fully charged (steady light) while it's not charged at all.  Yes both battery and charger is Canon.  When I put the battery in, the camera would show a fully charged battery but would show zero within minutes of use...this is my cliff example I was talking about.  To this day, I make sure the battery is charged by the time it takes in the charger, not by the charger indication.
I haven't asked for a replacement, maybe I should. But I was told the camera stayed in their facility for futher inspection is simply because I didn't want to take it back last week so it was not their fault. Of course I wounldn't, the technicians didn't watch the video at that time...
Based on what I was told, Canon will not do anything until they repro it. My video is not enough to convince them there is an issue with the camera.
The battery grip is a great idea. Thanks for pointing that out.
Not trying to disagree, but two technicians were not able to watch a simple video? I doubt they have tested well enough.
I agree the charger could be the weak link here. But that does not explain why the camera thought the battery had 92% power when it turned itself off showing empty battery.
VIP
Actually it does. If the battery, a lithium, gets to a certain discharge level, it can act this way. It will regenerate itself enough to run a few lesser demands but will fail when you ask it to work the shutter for instance.
I feel for you and I hope a solution is found. Whatever you must let me know how it turns out.
You are going to kick yourself if it does indeed turn out to be a simple battery or charger!  I almost hope it is the camera at this point of your frustration.
I definitely will.
Just got off phone with Canon again, the question I asked is whether they have charged my battery or not? If not, then it is not a battery issue or charger issue. It is me having magic failing cameras.
I will keep you all posted. I do hope it is a simple charger or battery issue, at least the fix will be simple then.  But I did send my charger and battery in the first time, and when I get the camera back, I was able to repro the issue that day.
powered by Lithium
