06-28-2015 09:51 AM - edited 06-28-2015 05:50 PM
06-28-2015 11:55 AM - edited 06-28-2015 11:56 AM
You are doing Infrared Astrophotography? Yes, so I assume you know your way around a camera?
Sometimes the most basic thing is overlooked. Make sure you Clear All Settings on both cameras. You did take it to a service man that understands IR cameras?
Can you show some samples with exif? And are you shooting the exact same subject at the exact time?
06-28-2015 03:29 PM
I own and use a 60Da. I'm not sure what you mean by "manual mode auto exposure". Normally astrophotography is always done in manual mode (because metering is worthless). Are you trying to get the camera to use auto-ISO? I wouldn't recommend that for astro-imaging work because the metering is not going to be reliable.
If you use any form of an auto exposure (even auto ISO) and the camera has any amount of image compensation dialed in then you could have this problem.
06-28-2015 05:34 PM - edited 06-28-2015 05:54 PM
Sorry, I did not make myself clear. I'm doing time lapse so I'm moving from bright sunlight to night. I use auto ISO adjustments along with manual adjustments. Here's an example, this has not been adjusted. https://vimeo.com/131782747
Since I had one repaired the images are darker when using the auto ISO.
I was hoping it was a setting. I will try to set up a test, but one or both cameras are running most of day.
Today I have downloaded over 10,000 images from both cameras, so knowing what came from camera is hard.
Sorry for the confusion
Thanks
Ron
06-29-2015 12:09 PM
@rondog99 wrote:Sorry, I did not make myself clear. I'm doing time lapse so I'm moving from bright sunlight to night. I use auto ISO adjustments along with manual adjustments. Here's an example, this has not been adjusted. https://vimeo.com/131782747
Thanks
Ron
Are you using the same metering mode on both cameras?
What metering mode is it?
Are both cameras aimed at the exact same place?
Are the cameras identical and do they have the same version of firmware?
07-05-2015 02:04 PM
One of the cameras won't start will reply when I get it working.
Thanks For your help.
Ron
