04-08-2013 11:00 AM
Hallo, I am using a Canon EOS 6D. In the specifications it is stated that the speed when doing the continuous shooting is 4.5 fps. I wonder if this speed changes depending on the setting regarding on how I save data on the card (raw, jpeg, raw+jpeg). Or it is ALWAYS 4.5 no matter how I save the data ?
Thanks
04-08-2013 12:07 PM
My interpretation of the spec is that it specifies how many FPS it can shoot when in good light with a good lens & it doesn't care about the file structure saved. That file goes into the buffer as the camera continues shooting & that becomes the limiting factor on HOW MANY shots you can take before the camera stops firing. A faster card helps a bit but transfer speed is really the limiting factor once the buffer starts to fill. From experience cameras writing to dual cards are slower than if instructed to only write to the CF card.
04-08-2013 12:10 PM
04-08-2013 05:24 PM
Yes, the number of shutters you can make will be determined by the size of the buffer. Not the file size itself.
Obviously if you set your shutter speed at 1 sec or ½ sec, ¼ sec, etc, you wold not see 4.5 FPS.
