10-01-2017 11:36 PM
Hello evryone,
I am using Canon 5D mark 3 for Photography I just started shooting. What is the best setting for sunrise and Sunset?
Thank you,
Mu.
10-02-2017 12:07 AM
There's nothing tricky about the settings, because you're usually focused on infinity and exposing for daylight.. With sunsets, start when it's still fairly bright and keep shooting until it gets so dark that everything is dull. Sunrises are just the reverse, but the problem with them is that while sunsets often get better as time passes, sunrises always get worse. So you have to start before the sun comes up, which means that you have to know where it's going to be.
Some may tell you that you need a tripod for sunsets. You don't. I've gotten several good sunset pictures, and I'm pretty sure all were hand-held. If you have to use a slow shutter speed on a sunset, it means you waited too long.
10-02-2017 12:11 AM
Bob,
I appreciate your input. I just check a youtube vedio about using the mode "P" underexposure I am just discovering now what is the option before i start shooting.
Thank you,
Mu.
10-02-2017 06:51 PM
@cleansensor wrote:Bob,
Thank you,
Mu.
I would suggest using Av mode, with a fixed ISO. You would need to pre-focus, and then switch your lens to MF. Having a remote shutter would be great. Be ready for it.
There is a several stop difference in light between the pre-dawn, first light, and full sunrise. The moment of first light will last only about a second, and you can get an exposure with the same settings as before the sun appeared. After that, the light intensity climbs rapidly, and it is best to have sun filters on your camera.
10-02-2017 06:58 PM
Hello there,
What is your suggestion to ISO? you mean use Autofocus and then switch to MF?
I have 3 fliters I did not use them yet. is there specific one for this matter?
Many thanks,
Mu.
10-02-2017 07:02 PM
@cleansensor wrote:
Hello there,
Many thanks,
Mu.
I cannot tell you what exposure settings to use. It can vary widely depending upon the lens and shooting conditions. I would suggest shooting in fully manual mode, though.
As for your filters, the same advice applies. I don’t know enough about your gear [lenses] and your shooting conditions.
10-02-2017 07:11 PM
Thank you!!
10-02-2017 09:15 PM
@cleansensor wrote:
Thank you!!
Use manual exposure, because the light conditions will coerce the camera into over exposing the shots.. Get there early, so you can take a number of exposure.
Every sunrise is different. The above shot is first light. A second later the exposure settings were a good 3-4 stops too high.
10-03-2017 10:05 PM
Thank you so much!!
10-03-2017 10:44 AM
Of course the correct answer is 'bracket'. Bracketing is your friend. Your camera can do 3 or 5 bracked exposuers in fractions of a second.
