01-18-2014 05:44 PM
I have had the 6D for about a month. I generally like the camera but find the Wifi to be technically limited and difficult to setup.
If someone can point me to a good tutorial on setting up the 6D's wifi, I would greatly appreciate it.
Technically limited: I live in a suburban area where all the neighbors seem to have 2.4Ghz routers. In other words this is a congested band and this limits the transfer rate. I wish this camera had a 5Ghz antenna. 5Ghz has limited range which is both a constraint and also an advantage because I can see no other 5Ghz users. So there is huge available bandwidth. But the 6D can't use it. The other technical limitation is that video can't be streamed over wifi. I wonder if this limitation is due to the limits of the 2.4Ghz band?
Setup: I have a Windows 8.1 workstation with a Gigabit ethernet network. The wifi is run via a dual-band wifi router with 2.4Ghz and 5Ghz 8.02.11n wifi networks. I have had limited success setting up an EOS Utility connection to the 6D. The above technical discussion is more theoretical than experience based because in a month of owning this camera I have been successful only once in getting the camera to pair up with a computer. Today I tried until I drained the battery and was not able to get the EOS utitility to connect to the camera. I was able to use the DNLA feature to connect to the picture folder on SD card in the camera. But I take only RAW format and the DNLA interface does not even show the .cr2 files much less display them and provide a transfer capability. Other than proving that the camera was detected by my network and by the computer this was an excercise in futility. On the computer the pairing software WFT lists the camera and I can click on the CONNECT button. But no connection was made that allowed the EOS utility software to become active.
I have a huge complaint with the setup software. It does not seem to remember my passphrase when I attempt to set it up for the EOS utility. I use WPA2 and have a long security phase. But the camera does not seem to remember this passphrase for my SSID. I click on my SSID in the list of SSIDs and then I get the screen to re-enter my pass phrase. Seriously? The camera does not share the passphrase between LAN functions and it does not seem to remember it in the EOS utility function from session to session. And there is no capability to see the passphrase once it is entered. All I see is 6 asterisks. These asterisks provide security? This seems to be an industry joke on the poor user so I guess I can't fault Canon for this level of thoughtless design. At least Windows 8 now provides a "eyeball" to click to see passwords as text and not only asterisks.
It sure would be useful to be able to set the Wifi passphrase using the USB cable interface. Then I could type it using a keyboard rather than the ridiculous thumbwheel interface in the camera. Does anyone know if it is possible to setup wifi via the USB interface? I know that wifi and USB are mutually exclusive but may be setting up the wifi could be allowed.
Canon's marketing makes wifi seem to be a reason to buy the 6D. In my opinion the Wifi function is over rated, a negative factor, and implemented poorly. Certainly it is not something that is useful enough to justify the 6D's price point or to select it over other manufacturers.
01-23-2014 06:20 PM
Hello SGFFX,
We're sorry to hear that you're having difficulties with the Wi Fi on your EOS 6D. We have an article that should be of help to you.
1. [Wi-Fi] is set to [Enable]
NOTEWhen the camera is connected to a computer, printer, GPS receiver, or any other devices via an interface cable, the settings for [Wi-Fi] cannot be changed. Disconnect the interface cable and then configure settings.
2. The camera is not connected properly to the computer with the supplied USB cable
3. The camera is not recognized by EOS Utility (You can only click [Monitor Folder] on the main window of EOS Utility)
4. CameraWindow is being used
If this is an urgent matter, please feel free to contact Technical Support directly. You can do this through our Service and Support web site.
01-23-2014 10:53 PM
Tim,
I'm not sure how your post helps me connect the 6D through wifi. It tells me how to disable wifi and connect a USB cable. Connecting a USB cable was never a problem. Yes, I am using the latest version of the EOS Utility. It works just fine with a USB cable.
In any case SUCCESS! I have the wifi connection between the computer and the EOS 6d working. I had to start the pairing software WFT by finding the executable in the Program Files (x86) folder and clicking on the executable. The WFT selection was greyed out in the EOS Utility menu. So starting WFT manually was the only option.
My best guess is part or all of my problem was due to the passphrase that is 35 characters long. I really take the guidance to enter a complex passphrase to heart. This is no problem when you can use a keyboard to enter the passphrase. I am a clutz when it comes to using the thrumbwheel and I must have been incorrectly entering it. I attemptied to enter it many times. It would not pair with WFT. When I would return to the passphrase screen I would see 5 or 6 asterisks. Retry entering the passphase and same result. But finally I was somehow successful and now I can connect whenever. The WFT pairing software now runs at Windows startup and is always in the taskbar.
My point: setting the wifi passphrase can be made user friendly. The limited ability to configure the camera via the EOS Utility seems unnessarily limited.
I don't understand the limitation that the wifi can't be configured when the USB cable is plugged in. Maybe I can understand why both USB and WiFi can't be used at the same time but not allowing the wifi to be configured is not understandable. In fact I question why it is not possible to set/change any and all options and parameters through the EOS Utility however the utility connects to the camera whether USB or wifi.
I also wish the camera had the ability to connect via the 5Ghz band. As I said in my original post the available bandwidth on 2.4Ghz is congested and the very best I can do is about 130mbits per second transfer and often much less. On my 5Ghz band I can get 300mbits per second. Maybe video could have been streamed from the camera at that bandwidth.
03-23-2014 07:36 PM
The latest version of EOS Utility 2.14 has a better implementation of the Wifi pairing that the previous version. I recommend upgrading to this version if you want a better interface for Wifi pairing.
Steve
07-07-2014 09:08 PM
08-27-2014 03:32 PM
And sadly, the users manual is fo 2.13, not 2.14
