08-24-2013 07:00 AM
Hi! I just recently ungraded from the 5D Mk ii to the iii. I know the focus system is pretty sophisticated on the iii, but a simple half press of the shutter to focus, and then holding while I recompose, isn't working... the lenses are refocusing elsewhere in the frame - usually at the longest distance. I've tried it with both my 24-105mmL and my 300mmL, and guess it is the same with all my lenses. This is also happening with the back-button focus. I've also lost the beep when focus is achieved. I believe it is something I am doing in the Case settings or elsewhere that is causing this because when I clear the camera settings, I have this function back. I'd just like to understand what I am doing that is causing the inability to recompose the shot after focusing. THanks!
08-24-2013 07:22 AM
.... actually, I think I've figured it out. I was shooting birds in flight and had the cam set to Case 5, and had made focus a priority. This must have caused the camera to refocus on a half shutter press when I went to shooting something else without changing the focus settings.
08-24-2013 07:22 AM
