Reply
Highlighted
New Contributor
Returning raw files to eos80d
Hello friends. I would like to return some raw files to the camera in order to process them into “watercolor” jpg. However copying them onto the SD card the camera doesn’t find the files. Any tips?
Highlighted
Esteemed Contributor
Re: Returning raw files to eos80d
Where did you put them? They need to be in the DCIM->100Canon folder:
If you have a more complicated folder structure, you may need to go dowh a level.
Highlighted
VIP
"Any tips?"
The camera has an SD, or CF doesn't matter, memory card, you simply need to place the memory card into the card reader on your PC. All you then need to do is copy the pictures you want to transfer to your camera and then paste them into the SD memory card.
Highlighted
New Contributor
Thank you both for your kind replies.  I have tried returning the files to the correct folder but I just get the  "No files" message.  I used a freshly formatted SD card, then updated the firmware and still no good.  I am a bit stuck!
Highlighted
Valued Contributor
If you have edited the raw files in any way then it is possible that the camera will no longer recognise them.
Highlighted
VIP
"If you have edited the raw files ..."
I doubt that is a cause.  No editor I know of alters the actual Raw file. The problem is, it is unlikely any editor would understand the edits if they were place inside the Raw file. And certainly no other image viewer would either.  However, I admit I don't use them all.
Highlighted
Valued Contributor
_________________________________________________________________________________________________
It certainly doesn't work if you make any alterations to the original file name.
Highlighted
Does DPP have the effect your trying to achieve?
Highlighted
VIP
I just tried it on my 1D Mk IV.  All jpg worked without problem. No cr2 file did.
I am going to try some more stuff to see why or if.
Highlighted
New Contributor
Thanks for all the thoughts.  Unfortunately it doesn't work with either raw (unedited) or jpg.
powered by Lithium
