Reply
New Contributor
Read Depth of field with EXIF data
Hi , i take macro photography and the main problem is depth of field .
To check I took pictures with a tripod , always from the same distance, ISO and shutter speed.
I only changed the aperture value. 7,1 -8 -10-16 .
I read the related Exif data focus distance upper / lower , but to my surprise they never change, they are always the same for all the shots.   why is this happening? .
If I use a simulation SW as a DOFsimulator ,this value varies .
I use Eos 5d mark iv + ef 100 L macro
Thanks Alessandro
VIP
Re: Read Depth of field with EXIF data
You did not provide any distance or DoF info.  It is not possible to answer your question without data. I assume that your subject is less than a foot from the camera.  Take a look at the top row of the Depth of Field Table.
New Contributor
Hi ,I shoot pictures at different distances, 30 -50-70 80 100 cm the result is in the table .
   EXIF
FileDistance cm FocusUpperFocusLowermm
Cm30_7_130 32311
Cm30_830 0,320,31
Cm30_1030 0,320,31
Cm30_1430 0,320,31
Cm50_7_150 54504
Cm50_850 0,540,5
Cm50_1050 ====
Cm50_1150 ====
Cm50_1650 ====
Cm70_7_170 74677
Cm70_870 ====
Cm70_1070 ====
Cm70_1170 ====
Cm70_1670 ====
Cm80_7_180 83749
Cm80_880
Cm80_1080
Cm80_1180
Cm80_1680
Cm100_7_1100 1099613
Cm100_8100
Cm100_10100
Cm100_11100
Cm100_16100
VIP
Thanks Alessandro
I am not familiar with any Canon camera that adds Depth of Field to the EXIF data, just an aperture setting.  Your printout is from your simulator,  which is not EXIF data.  These focusing distances are very small, and the estimated DoF are even smaller.
You are probably looking at rounding errors.  The software probably does not have enough significant digits to resolve those small differences in aperture at macro focusing distances.
New Contributor
Hi , The values ​​that I have highlighted are the reading of the Exif data of each single photo .
They are not simulated but real data  .
I wrote them in an excel file.
It may be that the sw rounds the values, because they are very small.
I will test with a normal lens and with greater distances.
Thanks
powered by Lithium
