Reply
New Contributor
Raw photos from 5D Mark iii is coming pink or reddish
I was recently on an international project while I was using my canon 5D mark iii. While shooting I observed that the raw photos are coming reddish or pinkish and also sometimes the data of previous shot is overlapping with the next one. Not sure exactly what is the problem. It is not consistent. Sometime consecutive 5-10 photos all coming that way then suddenly it stops and everything is normal. Restarting the camera, changing battery, changing memory card, changing lens - I tried all. But the problem exists .
If anyone knows the root cause of this problem or faved similar problem please let me if there is any resolution
Valued Contributor
Re: Raw photos from 5D Mark iii is coming pink or reddish
You need to post some sample pictures before anyone can really make a proper decision on this.
The overlapping problem is usually down to a faulty memory card, are you using a full sized card and not a micro SD with an adaptor and have you formatted the card in the camera.
VIP
What you describe is usually cosistent with using bad memory cards or unformatted cards.  You did not state what type of memory cards you are using or testing, SD or CF.  I hope that it is not a motherboard/sensor issue.
Frequent Contributor
I don't know if this is the issue but something similar happened to me.
Twice with 2 different CF cards, it turned out that when I viewed on the camera similar effect, downloading same
Turned out the card was very hot, after waiting and trying after the card was normal temperature they were okay.
So they were both SanDisk Extreme 256 GB cards
Canon 5DSR
I left it in the trunk and it became really hot, so if the same happened to you then take the card out of the camera and let it set.
powered by Lithium
