Reply
Occasional Contributor
Accepted Solution
RAW SHOOTING
Is their any reason to use AEB when shooting in Raw?
Canon 7D
Canon18-135 STM, 70-200 F2.8
2X Extender
580EX
Canon Elph 330HS
Canon Elph SD750
Re: RAW SHOOTING
jimsaloha
HDR come to mind. Also even without going the HDR route you can often get better results in post if you don't blow out the highlights. You can only bring it back so much in post even using RAW. I favor EC over AEB.
Ed
40D, 1D MKIV, 28-135mm, 24-70mmf2.8L, 70-200mmf2.8L, 500mmf4.0L, 580EXII, Gitzo3530LS w/Wimberly Gimbal, Manfrotto 190XBPROB and a bunch of other stuff.
Reputable Contributor
Re: RAW SHOOTING
If you plan to use it for HDR. Or when you're in a situation that changing too fast and you don't want to stumble around with the setting at the critical moment. In some situation, where the contrast is too great for single capture, you may want to turn it on.
Weekend Travelers Blog | Eastern Sierra Fall Color Guide
Topics: 1
Kudos: 22
Solutions: 3
Re: RAW SHOOTING
Like others have said, HDR is an obvious use. For HDR you might bracket +/- 1 1/2 or 2 EV.
Also where time is of the essence, like a sunset for instance, it can facilitate getting various exposures without having to adjust. Here you might only bracket +/- 1 EV.
If you have a body that can bracket more than 3 images, you can set it at +/-1, bracket 5, and have everything you would need for either normal or HDR processing.
http://trulandphoto.zenfolio.com/
http://trulandphoto.blogspot.com/
New Contributor
Re: RAW SHOOTING
You need to use the AEB feature because the RAW format can provide true EV range of only +- 0.5 EV.
If that's the range you need, then no need to bracket the shots.
But if you need a +-2 EV or something like that, using RAW file would cause loss of data and details. That's why it is best to use EV bracketing.
powered by Lithium
