Reply
New Contributor
R6 Issues - Brightness/Displays/Outdoors
Is anyone else having issues with their R6 and brightness? I am having two main issues: when I focus, as I push the button, everything lights up to what the shot really should look like, but only for a split second, and then it goes back to a much darker shot and that's what stays when I hit the trigger.
Also, when I'm out in a sunny day, the entire back of the screen and the viewfinder goes completely white. I can't see anything unless I crank my F stop up super high, as well as my shutter speed. I mean to REALLY high numbers to make things as dark as possible to even be able to SEE the scene. Doesn't matter which lens I have on.
I've been having these issues since I bought it in Fall. I've tried to adjust settings, factory resets, firmware updates, etc, but something is just really "off" with it (and not just outdoors). I barely touch it now because I'm so frustrated with it and don't enjoy it at all and regret buying it.
And just for the record, I can take the same shot, settings, etc just fine with my 5DMIV.
Reputable Contributor
Re: R6 Issues - Brightness/Displays/Outdoors
It sounds like you have your ISO cranked up very high.   For the scenario where you are seeing the all white screen, what are the current camera settings?
Ricky
EOS 5D IV, EF 50mm f/1.2L, EF 135mm f/2L, 600EX-RT (x6), ST-E3-RT
EOS C70, RF 24-70 f/2.8L IS
New Contributor
No, it wasn't. I should've clarified that in my post. Sorry. The whole thing is just puzzling.
Are you using flash at all? Perhaps the camera is switching the camera to the sync speed?
We'll need more information.  What settings/setup do you have?
Ricky
New Contributor
No, no flash.  I really don't know how else to explain it or the settings because no matter what I did, until I cranked everything up to make it dark, you couldn't see anything but this crazy blinding white screen/scene. I'll need to video it when we get a bright day again - should've did that yesterday. I was just hoping someone would have also experienced it and had a fix/suggestion.
VIP
You need to provide a little more information.  There are too many unknowns beginning with what lens you're using.
I recommend resetting the camera back to factory defaults, taking a few test shots in P mode.
New Contributor
Thanks. I'll just contact the support team and see if they can help. I really think it's a defect issue. It happens no matter what lens is on it. (Any of my RF, EF with adapter, etc.)  And I have reset to factory settings already but it didn't help it. But thank you. I appreciate the replies.
VIP
Do you have a camera store or a camera club nearby? They might be able to help hands on.
1D X Mark III, Many lenses, Pixma PRO-100, MX472, LR Classic
powered by Lithium
