07-01-2017 11:54 PM
I'm planning to buy a Canon EOS 6D Mark ii when it becomes available. I have some 20 year old EF mount USM lenses that I purchased in the late 90s with a 35mm EOS 5.
Are these old lenses compatible with a 6D mark ii?
If so, are there any limitations?
Thank you.
C
07-02-2017 07:02 AM
Both will work with the 6D2 but the quality may not be as good as more modern lenses. The trouble with getting a more modern body that has higher resolution is that any poor lens performance will be more obvious.
Providing you are not making large prints then both should give quite adequate performance.
07-02-2017 07:02 AM
07-02-2017 07:17 AM
Thanks Ray-uk.
That's what I thought, but needed to make sure.
Thanks again
C
07-03-2017 09:31 AM
"If so, are there any limitations?"
If I just bouhgt a brand new 6D Mk II, I would not put either of those on it. Why, I must ask?
