Reply
Occasional Contributor
Re: New Camera/Help
I tried it and letting it dry over night. I'll let you know if it fixed it!
Re: New Camera/Help
Thanks, that makes more sense to my now. Hopefully I can get the shutter button cleaned.
Re: New Camera/Help
It's fixed! I used some WD40, and contact cleaner. I'm going to get a keyboard air duster, and some alcohol to clean it out better. Thank you!
VIP
Re: New Camera/Help
I suggest that you quit while you're ahead.  Introducing foreign objects and substances into what should be a "clean room" type of environment is never a good thing.
Cameras and lenses, cameras most especially, should be cleaned by professionals.
Compressed air can introduce frozen air moisture onto surfaces where it is sprayed, because they sudden drop in pressure is accompanied by a sudden drop in temperature.  WD40 and electronics do not mix.  There is really no such thing as "contact cleaner", because any solvent leaves residue behind.
Valued Contributor
Re: New Camera/Help
Well done for fixing it, but in future do not even think about using WD40 on camera equipment it is not made to be a cleaner or a lubricant it is made to disperse water (hence the WD). Sometimes it can cause more problems than it cures because it dissolves some lubricants and can leave a nasty residue.
If you want to clean out the battery compartment use a little Isopropronal fluid on a brush otherwise as the previous post has stated "quit while you are ahead"
Re: New Camera/Help
I understand, there were a few times where the shutter button still didn't work so I want to clean it better. I understand that the WD40 was a bad idea won't be using that any more. I am going to try an isoproponal just once more and hopefully it fully fixes it.
Honored Contributor
Re: New Camera/Help
Just remember that some (all?) alcohols form a constant-boiling solution with water, which means that you can't get pure alcohol out of an aqueous solution by simple distillation. So what they do is add some amount of an adulterant, notably benzene. That gets the water out, but can leave a trace amount of benzene in the "pure" alcohol. And benzene may not be something you want disappearing into the recesses of your camera. It's one thing to use alcohol to clean lens contacts (of questionable efficacy, but harmless) and another to pour it around the shutter button.
Bob
powered by Lithium
