Reply
Highlighted
Occasional Contributor
Accepted Solution
My "New" Canon EOS R5 had over 1,500 shutter releases? Is this normal?
I received my R5 this morning and this afternoon I realized that it had 1,805 shutter releases on a brand new camera from B&H Photo. Is this normal? I'm guessing but can't believe that I pressed the shutter button more than 100 or possibly 200 times but 1,800?
Highlighted
VIP
Re: My "New" Canon EOS R5 had over 1,500 shutter releases? Is this normal?
How did you find out how many shutter presses it has had?  Does the camera tell you how many shutter presses it has?
Highlighted
Reputable Contributor
[ Edited ]
One thing that is worth considering...
Could it be that you, or someone along the way before you has inserted a card that was not completely clean - i.e. low-level formatted.   If continuous numbering is selected in the menu options  (and it has been by default in my experience) then the camera can pick up the numbering from an inserted card that has had an image count (even if it is formatted but not at low-level) and continue the numbering from then.
cheers Trevor
"All the beauty of life is made up of light and shadow", Leo Tolstoy;
"A good swordsman is more important than a good sword" Amit Kalantri
Highlighted
Respected Contributor
As Trevor noted, if you are going by file sequence number, then his explanation is the likely reason for what you observed.
My 1DX series DSLR bodies provide a shutter count to the nearest 1,000 increment so that you can schedule replacement before failure is likely, something that is important in pro level bodies which are frequently used in high speed drive and multiple events resulting in a very high number of shutter actuations in a short period of time.  But the 1 series are the only Canon DSLR bodies I have owned that provide this info within their menu display, is that information also being provided in the R5 series?
Rodger
EOS 1DX M3, 1DX M2, 1DX, 5DS R, 1D M2, EOS 650 (film), many lenses, XF400 video
Highlighted
Esteemed Contributor
And also, do you know whether it was mecahanical or electronic shutter? IIRC, the R5 has both.
Highlighted
Sorry Guys, I'm an idiot! When I saw the shutter count, I jumped to a conclusion that was 100% wrong.
I didn't realize that what I was seeing was the number of shutter releases of the BATTERY! My Bad! When I got my R5, the battery was only partially charged, and while I was waiting for the new battery to charge, I used a battery from my 80D which is compatible but lower capacity.
powered by Lithium
