Reply
New Contributor
Memory card
Can I ask for some help I have a Canon EOS 20D and when I take a single photograph I end up with 24 folders on my memory card is there any way I can stop this happening Thankyou
Reputable Contributor
Re: Memory card
What kind of file names do the folders have? Your camera may add a few folders that are required for saving image files, thumbnails and other information, but I'm thinking that no where near 24 files would be needed.
Did you format the memory card in the camera before using? Have you set the camera's calendar and clock?
VIP
Re: Memory card
It sounds like you might need a new camera, or a new memory card.  Try resetting the camera back to factory defaults.  Since memory cards are cheap, you might as well try a new one, if you can still find one that is compatible.
Honored Contributor
Re: Memory card
A wild guess would be that the 20D has a limit on the folder size and that the only way it can use the whole CF card is to chop it up that way. When you started taking pictures, did it actually start using one of the folders?
Bob
New Contributor
Re: Memory card
Yes named CANON100
Re: Memory card
@Urbexhermit wrote:
Yes named CANON100
Do you mean "yes", you formatted the card in-camera? Are all 24 folders named "CANON100"?
What size and brand of CF card are you using?
VIP
Re: Memory card
Make sure you know exactly what type of memory card your 20D takes.
You'll find plenty of manufacturers out there selling memory cards, all with similar-looking products and claiming similar capacity and performance. Not all memory cards are created equal.  CF cards can be made from varying quality of components and manufacturing standards. If you've bought a cheaper generic card you might want to get a high quality one. Always stay with cards from known good brands sold through authorised dealers. Counterfeit memory cards are also an issue when buying from sources like eBay. I would stay with a 8BG CF card.
powered by Lithium
