01-19-2021 01:33 PM
I have a Canon M6 mark II
I need an external flash, for some photography I'm taking a dance.
Unfortunately I do not want to take my viewfinder off.
I have a cage with plenty of hot shoe mounts one on top for the flash, and many on the side for a small wireless transmitting box.
I basically need an external flash and a box, that do not interfere with my hot shoe mount.
I'm curious if there is something that could plug into one of the ports on the camera, that I can mount on a cold shoe, plug into the camera, and mount my flash on a cold shoe.
Any thoughts?
01-19-2021 02:12 PM
The only way to trigger a flash is via the hot shoe.
If you had a built-in flash you could use that for a trigger.
01-19-2021 03:09 PM
01-19-2021 03:37 PM
You can buy trigger circuits that will ignore the pre-flash and trigger your external from the built-in flash.
01-19-2021 03:54 PM
01-19-2021 04:05 PM - last edited on 01-19-2021 04:25 PM by Danny
This link might not survive, but google "E-TTL optical flash trigger"
[This link's okay!]
01-19-2021 04:12 PM
01-19-2021 04:24 PM
Yep, that is the way it works.
01-19-2021 05:09 PM
01-19-2021 06:21 PM
No, you aren't fast enough for that! 8^)
You either put the M6 in manual mode so there is no pre-flash, or use a trigger that ignores the pre-flash.
