05-24-2021 02:45 PM
I bought a Canon 5D Mark II and received it today. The seller posted it as missing CF pin. I bought it for tethering so it is not a big concern to me.
When I connected it to Canon EOS Utilities and Light room, everything works okay. For less than $180, I can't complain at all.
The rear LCD displayed properly. However, when I looked into the viewfinder, I saw a small circle and not the full rectangle view.
I am investigating the problem. Please share your experience if you have encountered the same thing.
05-24-2021 04:41 PM
05-25-2021 02:26 AM
Hi huskyC,
Thanks for checking in with us!
From what you mentioned, it is possible that the focusing screen has gotten out of place, as John Hoffman suggested. To check this, turn off the camera, remove the lens and look into the camera. If you see a small gate hanging above the mirror, then that means the focusing screen has fallen loose.
The good news is that the focusing screen is designed to be easily removed and replaced by our photographers. That's because we have a few focusing screen accessories; some have grid lines and some are better for doing manual focus. Our photographers can select the focusing screen that best suits their needs and then easily swap a screen in and out when appropriate.
If you do see a hanging gate above the mirror, then make sure the focusing screen is seated correctly on the gate then slide it up to the roof until the gate clicks into position.
