03-20-2017 10:38 PM
03-21-2017 08:21 AM
03-21-2017 08:21 AM
03-21-2017 11:00 AM
03-21-2017 11:09 AM
Yep, check out Ken Rockwells review - I can't link to it here - but just google Ken Rockwell EF-S 10-18 review. It will also link to the 10-22 review if you want to check that out.
03-21-2017 04:34 PM
@Sunjeezy23 wrote:
That price is really reasonable! You think this lens will accomplish all that I plan to use it for?
Yes, it will work well for what you described.
If the plastic mount bothers you there is the EF-S 10-22. It's more expensive, doesn't have image stabilization, won't give you better image quality, but, it does have a metal mount.
03-21-2017 09:08 PM
@TTMartin wrote:
@Sunjeezy23 wrote:
That price is really reasonable! You think this lens will accomplish all that I plan to use it for?Yes, it will work well for what you described.
Contrasting Opinion:
I bought the EF-S because of the superior build quality, like the internal focusing and internal zooming. It also has a wider zoom range. The 10-22mm is also faster than the 10-18, and can give you f/4 out to 18mm. The 10-22mm is a big lens, but remarkably light for its' size.
With a SWA, super wide angle, lens you really do not need image stabilization, not unless you're doing a a low light, hand held close up. The above shot was captured by a Rebel T5 from a slowly moving and rocking boat, as it docked.
03-21-2017 02:39 PM
03-21-2017 02:46 PM
No I don't own it, but from the site I alluded to:
"The Canon 10-18 STM is all plastic, but good plastic. It's small enough that I don't worry about hitting it by accident and breaking it off a camera; there isn't enough leverage, and Canon's APS-C cameras aren't heavy enough."
