Reply
New Contributor
It isCanon Speedlite 600EX II-RT compatible with the Canon EOS 6D?
I would like to know if the Canon Speedlite 600EX II-RT  is compatible with the Canon EOS 6D
Honored Contributor
Re: It isCanon Speedlite 600EX II-RT compatible with the Canon EOS 6D?
Yes.
Bob
VIP
@RobertTheFat wrote:
Yes.
Good morning.  I hope you're right.  I noticed B&H put them on sale for less than the 600EX RT, so I ordered two.
Honored Contributor
Yes.
Just to be clear, I have neither a 6D nor a 600EX II-RT. (The closest I come is a 5D3 and a 600EX-RT.) But the Mk II is an ETTL device, and the differences fronm the Mk I are relatively minor. So there certainly shouldn't be any incompatibility. I.e., I'm sure none was intended.  Smiley Happy
Bob
VIP
Yes.
I never had any doubt about compatibility until I tried to ise it.  It didn't work.  No communication between camera and flash.
I got the flash, charged it up, mounted it on camera, switched everybody on, and nothing.  The camera would not recognize, and talk to the flash.  The flash fired, but images were way overexposed.  If I dialed back the flash to 1/128, then shots were as severely overexposed, but the flash still wouldn't talk to the camera.
The 6D kept telling me flash was turned off, or an incompatible flash was attached.  I would get the same message if tried to enter the flash special functions menu, too.  Tried a different camera, 80D, and it worked just fine.  I gave one of the two flashes to my in-law with the 80D.
Then, I had a stroke of genius, I tried the second flash I had ordered.  Taa-Daa.  The second flash wouldn't talks to the 6D, either.  I double checked that I had external flash enabled,which it was.  I still couldn't get commnication between camera and flash with the 6D
Then, I had a stroke of genius.  I went into the 6D camera menus and disabled the external flash, which greyed out the other menu choices associated with the flash.  Except, the flash special functions was still lit.  I tried it, and it worked.  I saw all of the special functions that I had seen with the 80D.  So, I re-enabled the external flash in the 6D menu.  Suddenly, the 6D and the flash were talking, just like they were with the 80D.  Test shots were not overexposed.  So far, so good.
Now, I have to figure out how best to use the thing, so that I don't have to use green square mode all the time.
powered by Lithium
