10-20-2015 07:26 PM
I wanted to upgrade from my Rebel. I have several lenses already and noticed that when I use them on my 6D there is a round black ring around the outside edges. Upon reading it seems that the Rebel has a "cropped frame" and the 6D has a "full frame". Does this mean that I have to get all new lenses to use with my 6D, and make sure they are EF?
10-23-2015 10:22 PM
Please buy and use only compatible lenses on your cameras.
Compatibility is important. If you are not sure, use only Canon EF lenses on your 6D. (in the case of your 20D, use both EF and EF-S lenses)
Don't just buy any lenses if you are not sure. Don't buy third part lenses if you are not sure.
Do some researches and start from the very basic. Kit lenses are something not bad. e.g. EF24 105 and EF 24 70 F4. Buy a cheap 17 40 F4 and you have covered from UWA to short tele.
Good luck.
New Tamron and Sigma lenses are very good too but they are not cheap. Some have AF consistency problem and may not be as stable as Canon lenses.
10-24-2015 12:22 AM
@lly3988 wrote:Please buy and use only compatible lenses on your cameras.
Apparently you did not read the whole thread. My lenses were fine and compatible with the two cameras I did have. The problem was that I upgraded to a 6D not realizing that it was a full frame as my other two were cropped frame.
I appreciate your advice, but I am going to have to get lenses that are made for my 6D now.
10-24-2015 10:04 AM
10-24-2015 09:40 PM
