Reply
New Contributor
How can I remove the white rectangle from Canon 5D Mark iii while streaming?
[ Edited ]
Is there anyway to remove the white rectangle on my Canon 5D Mark III?
I'm streaming a live yoga class into an Elgato HD60+ then into my MacBook Pro. I'm wondering if I need to do download the Magic Lantern firmware? I'd rather not do that if possible. Any suggestions? Thanks!
Respected Contributor
Re: How can I remove the white rectangle from Canon 5D Mark iii while streaming?
Paul9000,
You can try pressing the <INFO> button on the camera.  Multiple button presses will change the on screen display until it eventually reaches a spot where it's blank and then back to full information display with several steps in between.  This should change what you see onscreen as a result.
New Contributor
No this did not help. I spent a long time with Canon supp...
No this did not help. I spent a long time with Canon support on the phone and came to the conclusion the hdmi is clean when feeding into a TV but NOT the elgato hd60+ capture card. I was able to get over these limitations by downloading the Magic Lantern firmware as suggested by one of your techs. Disappointing that Canon does not offer these features in its own firmware. Also disappointing that I had to spend many many hours trying to figure this out.
Moderator
Re: No this did not help. I spent a long time with Canon supp...
Hello, Paul9000.
The 5D Mark III does not offer clean HDMI out, however, we do have a new EOS Webcam Utility Beta Software that may allow you to stream via USB. You can learn more at canon.us/livestream
You will also see all of the current models that offer clean HDMI out.
If your camera isn't listed, be sure to sign up to be notified for future EOS Webcam Utility Software updates & releases, as our team is actively developing the software and will be adding more camera models in the future.
New Contributor
Set camera to manual focus. No more focus box around your face. Magic.
New Contributor
AF off           |  AF on.
No matter what, i see a box.  From my camera through camlink.
SURELY there's a way to fix this in the settings.
Do I really need to downgrade to 1.2.3, then install magic lantern to get this done?
I'm currently on 1.3.6
( 5d mark III )
This is super annoying.
New Contributor
Paul9000, I’ve installed ML. What setting do I use to get rid of that white box?
New Contributor
I finally did get the white box to go away, after installing Magic Lantern.
New Contributor
Typically, hit the info button and it'll go away.
New Contributor
Thank you!  That worked!!!  YAY!!!
powered by Lithium
