Reply
Super Contributor
Re: How abut those fireworks? Did you get any good shots?
You implied a "better low light" camera would do a better job shooting fireworks.
that is not what i was implying...nor what i said.  i said your camera was better in lower light than mine, and wondered if my camera could deal with the lower light as well as yours, and i don't think it can.  I never said anything about not taking as good a picture because of my camera.  But even so, i don't believe my talent at this time would permit me to do as good as you did here,  if i had your camera.  Now what part of what i'm saying now that you don't understand????   Being critical for critcal sake serves no purpose.
VIP
"that is not what i was implying...nor what i said."
It isn't?
".. then too, both you guys cameras are much better in low light than mine."
That is a direct copy and paste quote.  I didn't make it up.   If it doesn't imply the camera made the difference, I need a refresher English course.
I think at this time our relationship needs to part.  Good luck with all your photograhpy.
Super Contributor
have it your way biggs, you can be right.
Honored Contributor
@jazzman1 wrote:
hey guys, i never shot fireworks before so this info is good to know.  i also know any available light would change the varibles. i did'nt know the light from fireworks would make as much difference as it seemingly does, even being far away.  then too, both you guys cameras are much better in low light than mine.   i do change my settings for different situations and lighting.  i no longer use auto.
There are two operative points here: 1) Fireworks are not necessarily a "low light" situation; and 2) since you usually want to see the "trails" made by the burning elements, you're likely to use a slow shutter speed. A camera doesn't have to be particularly good in low light in order to photograph fireworks.
Bob
Esteemed Contributor
The camera will not be an issue.  Any DSLR can do this:
This isn't shot with my 5D II or III... this was shot with my Rebel T1i (years ago).  This is ISO 100, f/11, and a 4 second exposure.
I've bolded the ISO to call attention to the fact that this was taken at base ISO (you do not need a camera that can produce low noise at high ISO because you don't necessairly need high ISO).  Also notice that I'm using f/11 here.
It's pretty bright and you can see that I could probably have reduced the aperture to f/16 and still had a lot of light.
The shutter speed doesn't control light here ... only the aperture does (well, and ISO sensitivity but that's already down to ISO 100).  So basically I'm using f/11 to avoid over-exposure and the shutter speed is simply allowing the capture of the trails.
I actually showed up for a party, was completely unaware that there were going to be any fireworks, and didn't have a tripod.  So these are hand-held and I'm doing my best to rest the camera on an object so I can hold the shutter open without moving it.
Tim Campbell
5D III, 5D IV, 60Da
Super Contributor
Hey bob, thanks for that info.  i have to look at this senario all over again from what you're saying.  i see that light really is what cameras are all about.  I'm going to give it a shot next time I can catch fireworks.  Thanks for the info.
Super Contributor
Hey Tim.  You guys are really throwing me for a loop here.  Had you and Bob not told me this, i would have thought shooting at night at ISO 100 and getting good shots was not possible, least not with my camera and lens.  I have not shot alot yet at night but when I have my results were not stellar.  I mean, i've had my shutter not fire at all at times, and had to move closer to some light and boost my ISO up to 1600 or more and change my f stop.  And the shots I have got i did'nt think was good.  The only night shots i've taken  I deem spectacular was with my Canon SX 60 P&S at appox 1,000mm or so, shooting a full moon.  Now that pic is spectaculr, taken in auto.   But my 24-105 L and 70-300 L fastest aperture is f4.   I thought to be able to get shots at night with my 60D like you and biggs have here...i'd need a faster lens.  But if I understand what you and Bob are telling me, that may not be so.
Question.... what's the fastest f stop of the lens you guys used with your night shots????    f2.8 ?????
Super Contributor
Bob and Tim, this is the best night shot I ever took.  I took this in auto, appox 1,000mm, with my Canon SX 60 HS P&S.  I have tried to duplicate this shot with my EF 70-300mm L to no avail.  I must be doing something wrong with my 60D and Lens.  Maybe this is not such a great shot, but I thought it is.IMG_0789.JPG
You'll want to switch the lens to "manual focus" and pre-focus the lens to the distance for your fireworks. If the lens is on "auto focus" and you are in "one shot" mode then it may struggle to focus and it would refuse to take a shot until it believes it has focused. When you switch to "manual focus" all that goes away and the camera will take the shot whenever you press the shutter release.
The fireworks emit their own light and are quite bright. Nothing else in the area will get much light (you'd need a longer exposure if you wanted the landscape to show up) but the fireworks themselves will be... well you can see for yourself in these images.
A tripod helps (I didn't have one and was resting the camera on something. I didn't know there was to be a fireworks display (or I would have brought a tripod).
I didn't actually use "bulb" mode (thought that would have been better had I known and brought my external wired shutter release). So I just dialed in a 4 second exposure and as I heard the mortar fire, I'd release the shutter to capture the trail of the mortar going up and enough time to capture the burst as it explodes and leaves the trail. I found 4 seconds worked pretty well (and yes, there were lots of botched images as I worked out the best time to press the shutter release.)
The moon is pretty bright too! f/11 and set the shutter to the inverse of the ISO setting (e.g. at ISO 100 use 1/100th. At ISO 200 use 1/200th, etc.)
BTW, I did use a 14mm wide angle lens. I was fairly close and long lenses wouldn't have captured much of the images (and you'd need to be able predict where the shell would explode.)
Tim Campbell
5D III, 5D IV, 60Da
Respected Contributor
[ Edited ]
2015-07-04;Sparklers and pool 2 (10 of 12).JPGI was aiming a bit lower and smaller...
2015-07-04;Sparklers and pool 2 (11 of 12).JPG2015-07-04;Sparklers and pool 2 (9 of 12).JPG2015-07-04;Sparklers and pool 2 (7 of 12).JPG
Scott
powered by Lithium
