Reply
New Contributor
Accepted Solution
HELP, Rokinon 14mm AF on EOS R does not MF
I am using FW 1.6.0 on my EOS R. I just received my Rokinon 14mm AF Canon EF mount lens. When I use manual focus, it delays, fires the shutter, then freezes up for about 40 seconds. Ultimately the photo is taken, but this is not how it should act. I have release shutter without a lens enabled. When I attach this lens to a t5 or t3i, it works absolutely fine in MF mode. Any thoughts as to what I am missing?
Forum Elite
Re: HELP, Rokinon 14mm AF on EOS R does not MF
" I have release shutter without a lens enabled"
Do a factory reset first. The set to shoot without lens.
Reputable Contributor
Does your lens have an AF chip installed? I have noticed that some cameras behave strangley with some AF chips.
Mike Sowsun
80D, 5D Mk III
VIP
Exactly which lens are you using?  It sounds like there is some issue with THE LENS, not the camera.  It the Rokinon lens does not work properly on the EOS R, Rokinon owns that problem.
New Contributor
I believe it is a camera problem. This lens works as it should on a t5 and t3i. I don't have any other acquantances that shoot canon to test it on but it is only my EOS R that malfunctions with it.
New Contributor
This lens does have the AF chip, but I would think that shouldn't matter when in MF mode?
[ Edited ]
Sorry, I was thinking you had the older Manual Focus of that lens with an AF chip.
There must be an incompatibility problem between the Rokinon lens and your EOS R.  The fact that your EOS R works fine with Canon lenses means that Rokinon has not "reverse engineered" enough to make it work with the advanced features of the EOS R.
I assume you must have you have the EF version and not the RF version since you can use it on the T5 and T3i. That means you must be using an EF to RF adapter. Is it a Canon brand or 3rd party adapter? Either way that adds another layer of uncertainty.
 Rokinon may be able to update the lens at some point.
Mike Sowsun
80D, 5D Mk III
VIP
Again. Exactly which model lens are you using?
It seems that you may have an old lens that works with old cameras, but not a relatively new camera. Sorry, but that is a lens problem. Old lens does not work with more recent camera body.
BTW, you might not need to enable releasing the shutter without a lens. It should not make a difference, though.
VIP
https://community.usa.canon.com/t5/EOS/Help-EOS-R-with-Samyang-14mm-f2-8-shutter-won-t-fire/td-p/259...
1D X Mark III, Many lenses, Pixma PRO-100, MX472, LR Classic
VIP
The “Rokinon 14mm AF” Lens does not use a Dandelion AE chip. It is an autofocusing lens, not a manual lens with a focus confirmation chip.
powered by Lithium
