03-17-2021 09:09 PM - edited 03-17-2021 09:45 PM
Hello I hope you can help. My LCD display on the backof my Canon 80D does not light up at al although my camera otherwise seems to work. This happened shortly after I was trying to take a few videos which did't work. I looked at the pictures from my shoot, couuld see them fine. But when I got home I could see NOTHING in the LCD. So I can't format a card or see any settings. I tried ALL buttons I could find including the INFO button and the INFO combined with the AF. The viewfinder display and camera otherwise seems to work fine. Any ideas? I obviously can't use the camera like this, none of the settings are displayed, can't see photos after I shoot them, etc. (Didn't drop or get camera wet, etc.). the battery is fine, the card is fine. Then Sensor Cleaning Light DOES come on when turning camera on/off.(????) Any thoughts VERY appreciated!!!!
03-18-2021 04:42 AM
Contact Canon Support. Sounds like your screen may have died, and needs replacement.
03-18-2021 08:56 AM
Do you have the little eye sensor above the viewfinder that turns off the display? Sometimes the eyepiece dislodges and covers it. At least it does on some Rebels.
03-18-2021 10:38 AM
As far as I can see It is hardly possible to offer any simple solution here. Most likely, you need to contact a specialist who will test your specific model.
Or try to contact the official technical support: https://www.usa.canon.com/internet/portal/us/home/support
05-22-2021 03:24 PM
