Reply
New Contributor
Grad ND Filters
first time buyer off ND Grad Filters for my EOS 6D - some advice would be very welcome. Thank you.
VIP
Re: Grad ND Filters
I don't use graduated ND filters.  You can add digital filters in post that can do the same thing, and with even greater precision.  You can shape the filter, and use multiple overlapping filters to achieve the precise effect you need.
About the only real use I would have for an ND filter is if I were in a situation where I was shooting with a very wide aperture and had too much light, which is actually pretty rare.  I have experimented with photographing the Moon with them, too.
Honored Contributor
Re: Grad ND Filters
As with a polarizer, don't buy any lens whose front element rotates when the lens is zoomed or focused.
Bob
Esteemed Contributor
Re: Grad ND Filters
If you really want one, use one with an external holder so that  the graduation can be adjusted up and down to hit the horizon.
I agree with Wadizzle. Don't bother with the filter, simply take a bunch of exposures and put them together in post - possibly with HDR software.
Respected Contributor
Re: Grad ND Filters
[ Edited ]
There are very few filters that can not be duplicated with digital post processing.
A gradient ND filter is not one of them.
The only filters that can not be duplicated with digital technique are a polarizing filter and a regular ND filters.
So my advice would be to skip buying on and save some money.
VIP
Re: Grad ND Filters
Here is an example of using digital filters in post processing, instead of an ND filter.
Notice the appearance of the falling water.  I didn't use an ND filter to achieve the effect on the water.  In addition, I also brightened up the water cascading down the steps with a few Radial Filters.  This water was moving very quickly, and the photo was about a half second exposure, shot at f/22.  The most glaring "flaw" were the dark areas, which were cleaned up in post using Lightroom.
VIP
Re: Grad ND Filters
As most of the consensus form above is, filters are mostly obsolete.  Learning and how adapt you are at post processing is by far the best way to go.
"The only filters that can not be duplicated with digital technique are a polarizing filter and a regular ND filters."
This statement is only true depending on how well you know how to use editors like Photoshop or not.  This person probably doesn't know how.  I agree a polarizer is likely the most difficult to master in post but it is possible.  It does take advanced skills in PS and a lot of time so I generally still use a polarizer, occasionally.  However I never use any of the several dozen filters I had for my film gear.  They now collect dust and are doing a fine job of it.
A gradient filter is one of the easiest filters to duplicate in post.  It even has a tool built in.   An ND usually requires layers to accomplish but is also possible.  The polerizer requires the use of channels and layers.
Re: Grad ND Filters
So Photoshop can reveal what is behind a blown highlight caused by a reflection that a polarizer can remove?
Amazing!
http://www.bobatkins.com/photography/technical/polarizers.html
Note the picture with the frog.
Honored Contributor
Re: Grad ND Filters
One common use of a polarizer is to get rid of reflections on water, exposing what lies below the surface. And a ND filter can be used to prevent blown highlights. How do you propose to perform those tasks in post-processing, no matter how advanced your skills are and how much time you're willing to spend?
Bob
VIP
Re: Grad ND Filters
I suppose neither of you read this, " I agree a polarizer is likely the most difficult to master ..."  It does depend on how advanced you are in the use of PS.
In some cases HDR is used to enhance the ND filter effect.  Highlights can easily be captured and even the very darkest parts in a shot.
I don't intend on giving a class on how to use PS here on the Canon forum.  If you want to learn how to use PS check into courses by some of the best like Ben Wilmore.  There you can learn how.  You can even put a frog where a frog can't be seen! Smiley Happy
powered by Lithium
