Reply
New Contributor
Re: Good Memory card (size & brand)?
Been a Sandisk customer always, just remember that Sandisk includes a lifetime warranty in some of their Pro or Extreme models. I got 2 months ago a problem with a Sandisk extreme SD I broke the plastic switch lock, contacted Sandisk in their webpage and and by phone got a free replacement, need to send by mail the old card before I get the new one.
Respected Contributor
Hello easygeorge,
1.  There isn't one specific brand which is best for a shooting video, but it is important that one uses large capacity SD cards rated SD Speed Class 6 or higher.  This will ensure you have both the capacity and speed to capture video.
2.  We shy away from recommending cards with adapters because the adapters can add thickness and may become lodged in the camera.  Therefore only "full size" SD cards are recommended.
3.  The camera stops recording automatically after hitting a 4GB limit, and starts a new clip.  This is normal, and if you are shooting HD video, 1920 x 1080, this limit can be reached quickly.
4.  To format the card go into the Menu> Setup Menu 1 (Wrench with dot)> Format Card> OK> OK
This will erase all the data on the card, so please be sure there is nothing you need to keep still on the card.
5.  We do not recommend switching cards between devices unless you properly format the card in the camera first as this will clear the card and format it for use in the camera.
Occasional Contributor
i have a CanonRebel t5i ,,,, i notice that the the on video mode it stops every ten minutes ,,, which is the best sd card to use when video taping ??? please let me know.. thanks
VIP
[ Edited ]
You could be seeing the correct behavior.  Refresh yourself with your manual.  There are file size and recording time limitations associated with video files, which can cary widely depending upon the video resolution and video file format that you use.
thank you for the information .... makes perfect sense
thanks for the information
powered by Lithium
