Focussing issue with 5D Mark III
crockny
Enthusiast
I am using my relatively new 5D Mark III with my old 400mm 5.6 lens for bird photography.  It often will not grab focus.  I have to manually focus closer before it focuses.  It doesn't seem to matter which distance setting I use on the lens.
So I am missing quite a few bird shots.  I have no problem when using my old 7D.
I don't know if this is a full-frame issue, my particular copy of the camera issue, the combination of lens and camera, or something in my setup, even though I followed an online tutorial for setting up the 5D Mark III for bird photography.
Anyone have experience with this issue?
diverhank
I have the 5d3 and the 400mm f/5.6L and often shoot with the combo and I never had any problems like yours.  There is one thing you should check...the option called "Lens drive when AF impossible" -purple AF4 - make sure this option is set to ON:continue focus search.  Setting it to off will often stall the focusing
Diverhank's photos on Flickr
24 REPLIES 24
"... not when the difference is make or break getting a once in a season shot."
And who gives a ---- about battery life.  Take two batteries for pete's sake.  Smiley Frustrated
Changing batteries takes time, too.  Smiley Wink  More time than nudging the lens.
"Changing batteries takes time ..."
That's why most folks do it at home 'after' the shoot.  Not during the shoot.  Must be a trick to charge your battery in the field shooting a BIF.  You have my permission, nudge away!
Yup, I do it at home.  But, some guy just told me to do change them in the field.
I'm not a fan of battery grips; but that, after all, is what they're for.
Bob
Yes, I use a grip.  AI Servo can consume batteries, too, at times.  I just feel that option to let the lens keep hunting for focus serves me no purpose.  [I have lost more shots than what I have gained from it.]
[EDIT]  I suspect Diverhawk has a valid point about the feature being outdated.  When it kicks in [continued focusing, or hunting IMHO], the lens is usually at a point where it isn't going to lock focus quickly
I most often have the issue when focusing on something small in the distance ...
It may be as simple as that ... I did the same experiment twice on static subjects and had trouble with my regular settings but not when I switched the "lens drive when AF impossible" to ON ... go figure. I know I changed this setting for a reason ... probably too much "hunting" at some point ...
I hear ya about the too much hunting.  Exactly why I have it turned OFF.  I use the center point for focusing, with assist points when I use AI Servo.
BTW, I think your 400 f/5.6 can tolerate a 1.4x extender on a 5D3, provided you use the center AF point.  AF points have set upper limits on f/stop that they can still focus.  Some high end cameras can go to f/8.
Turning this option on does not affect hunting at all in my experience. This option is designed for larger lenses not the 400/5.6. Even for the 600 f/4, it never hunts. Personally that option is out dated, designed for old super teles. All it does now is stalling your focusing
Enter for a chance to win!
April 20th-28th
