04-22-2016 01:50 PM
There were old threads regarding the Error 80 on 5DMk3, but I haven't seen any recent updates regarding this. Has anyone ever found an answer to this? I have experienced it probably at least once a week when shooting stills since the camera was newly released, but now I am needing to use the camera for video and it does it on almost every video I do. Stills you only lost the one image, but losing an entire video during a live broadcast, is unacceptable. Fortunately I have the 5dMk2 to switch back to for video, but the quality and sound aren't as good.
I am updated on firmware.
I only use Canon batteries.
I only use Canon L Lenses.
All cards are SanDisk and Lexar.
Any help appreciated.
Thanks!
04-22-2016 03:21 PM - edited 04-22-2016 03:23 PM
Well, you seem to have most every base covered. You could have old cards, but I doubt your entire collection would go bad at once. The odds of that are pretty slim.
I would try performing a low level format in a computer, and then a regular format, not a low level format, in the camera.
For those who do not know, I would compare a low level format to raw road buildling, with bulldozers, road pavers, and everything else, which is time consuming. I would compare a regular format to painting the stripes on the newly laid road.
Technically, a low level format initializes all of the storage locations throughout memory. It also tests each memory location, and flags the bad ones for non-use. A low level format is automatically followed by a regular format, which initializes the disk with an initial storage folder, or root directory. But, it is the flagging of bad sectors during a low-level format which might be beneficial in this case. Computers are better at flagging bad sectors than the camera, most likely. Performing a regular format in the camera should initialize the folders with names the camera uses.
04-22-2016 08:06 PM
@Waddizzle wrote:Well, you seem to have most every base covered. You could have old cards, but I doubt your entire collection would go bad at once. The odds of that are pretty slim.
Good advice, with one caveat: Computers can format a card with file systems that some or all cameras can't read. Somebody correct me if I'm wrong, but I believe that FAT32 is safe on pretty much all cameras these days.
04-22-2016 07:20 PM
