11-17-2016 07:56 AM
hello all, i have last night updated my macbook air to Siera version 10.12 and now cannot connect my 7d mkii to my pc. I have looked around forums and by using the system information file i can see the camera when it is plugged in but it now no longer seems to communicate with my mac, it would normally automatically try and import pictures when i connect it via usb.
any help much appreciated
11-17-2016 09:33 AM
What program do you use to transfer your files?
Try running ImageCapture and then plugging the camera in.
11-18-2016 08:46 AM
On connecting via USB normally 'photos' opens on my mac and the camera can be seen as an external device...now nothing
11-18-2016 09:37 PM
Have you tried a new cable.
11-19-2016 11:00 AM
11-19-2016 11:30 AM
Is it that your mac doesn't detect the 7D II ... or is it that the mac doesn't automatically launch a program to import pictures when the camera is connected.
These two different things (I know it seems subtle) would be completely different problems.
If you want a program to automatically be launched when you attach a camera, there are a few ways to do it. Apple's own photo software (Photos and Aperture) both have options that let you indicate if they should automatically launch when a camera is connected.
However a more universal way is to use Apple's "Image Capture" program (it's in your Applications folder and it's something you've probably never ued before.) Launch this and connect your camera. In the lower left corner is a tiny triangle (probably the pointy end of the triangle is pointing up). Click that triangle and it should open a window which reads: "Connection this camera opens:" with a selection item that lets you pick an application. You can literally pick ANY application you want. You'll see all the Apple programs that can handle the camera... but suppose you want to auto-launch Lightroom... just pick 'other' and then it'll open a file selection window and you can navigate to the Lightroom application and set that.
Having done this, when you connect your camera in the future, it'll auto-launch whichever program you picked.
I personally have a few programs I use... from EOS Utility to LIghtroom to Kuvik Capture and even a few others... so I dislike having one particular program auto-launch. So on my personal mac I set the choice to "no application" and I manually launch whatever application I need to use.
04-22-2019 09:19 AM
Take the WiFi card out it worked for me
03-25-2018 01:17 PM
04-20-2019 04:32 PM
Awesome!! Finally a solution that worked. Much appreciated.
04-22-2019 09:18 AM
Its not a fault but is documented in to maneal, really glad i could be of some help to you....
