Reply
Occasional Contributor
Re: Eos 7d Mk1 Mirror Freezes in Photo Mode
I have already done this with both of my batteries, and cleaned the contacts on both of them and in the compartment, as well as replacing the clock battery, no difference unfortunately
I finally got an error code: 40, I don't know if I didn't notice I previously or if it just started showing up
I did finally get an error code: 40. Took several times of "crashing it" the before it showed up, although I may have missed it I don't know
Respected Contributor
ah ok!
I have tried a few settings changes but nothing has worked, I went out this afternoon and shot with it using the screen, no problems, didn't even want to attempt the eyepiece just in case
VIP
Error Code 40 is a power malfunction has been detected.  Are you using genuine Canon batteries?
Have you tried to power up the camera without a memory card?  Without a lens?  Without either?
Reputable Contributor
Err 40 is a fairly generic "power issue" that can be set by many different failures and problems.
Flipping the mirror in a DSLR is a fairly significant peak power drain task so a problem with the battery or the contact interface between the battery and the camera can easily be an issue causing this error to occur when a sudden increase in battery current is demanded causing system voltage to drop below the critical level.
I haven't used a 7D series but do you have an AC adapter for it and how does it connect?  If possible try the AC adapter to narrow down the issue.  The aperture is also being changed at the moment the image is taken so try setting it up in Av or manual mode with the selected lens aperture set to the maximum opening of the lens (which is used during setup/focusing).
If replacing the battery or cleaning the contacts doesn't do it then you are going to have to send it in for repair.  It is possible that the mechanism used to flip the mirror out of the image path is defective causing it to draw excessive current but more likely there is an issue either with the power bus or power bus sensing circuit on the main board.
Rodger
EOS 1DX M2, 1DX, 1D M2, EOS 650 (film), many lenses, XF400 video
I am using genuine Canon batteries-I have tested the both of them and it doesn't seem to have made a difference. The camera will turn on and works fine so long as I am not shooting photos with the eyepiece, I don't seem to have any problems without a lense but of the 6 now that I have tried all of them cause an error. As for cards I have tried 3 separate ones and tried without to no avail.
Have you cleaned the contacts on the camera body where the lens mounts with an eraser?
I do not have an AC power adapter, but have cleaned the contacts for everything, flash, lense, battery etc. opening my aperture completely doesn't seem to have made a difference, although I managed to take more than one for once before it gave me an error
powered by Lithium
