Reply
New Contributor
EOS ds1 MKII and studio light
have an EOS ds1 MkII and Speeotron lighting.   Its not recommended connect directly so is the Wien Safety Sync the option options or are there others?
Thanks
Respected Contributor
Re: EOS ds1 MKII and studio light
Do you own an older Speedotron unit?  The units made in recent years works fine with the PC terminal on Canon 1 series equipment which is rated for up to 250 volts.
If your strobes are of the older type, then you will need to use one of the buffer/interface triggers but there is no need for that with modern flash units which already use low voltage triggering lines.  The manual for your studio strobe will show the sync voltage level.
Rodger
EOS 1DX M3, 1DX M2, 1DX, 5DS R, 1D M2, EOS 650 (film), many lenses, XF400 video
powered by Lithium
