Reply
New Contributor
Accepted Solution
EOS R - Trouble Turning on AEB
Hi
I just got an EOS R and I am having an issue getting it into the AEB mode, to take 3 bracketed shots. I have no problem setting this up on my 70D but not so for the R. I am probably missing something obvious.
I have done the following:
  •   Set the number of bracketed shots to 3
  •   Set High Speed Continuous drive mode.
  •   I have tried modes such as Av, Tv, M (M works on my 70D)
  •   In the Quick screen (and menu), I have selected Expo.comp./AEB and turned the appropriate dial, but it doesn't turn one exposure into 3 like on the 70 D.
  • Googled this issue but didn't find anything helpful.
In the Exposure comp./AEB settings menu, the AEB is grayed out.
I have tried a number of things, all which work on my 70D, so I am not sure what I am missing here. I can give more information if needed.
Thanks in advance.
New Contributor
Re: EOS R - Trouble Turning on AEB
Probelm solved
I finally found the answer to my issue, I had to set Silent shutter to OFF. Now bracketing works!
Reputable Contributor
Thanks for at least reporting back about how you cured your problem.
Your post may save somebody else a lot of grief. Robot LOL
powered by Lithium
