EOS R 100-400 IS problem
KirkD
The image stabilization in my Canon 100-400 Mark II L is running continuously as long as my EOS R is turned on. It should not be doing this. Previously, on my 6D, IS would only turn on when I depressed the shutter button half way and when I let go, it would turn off after a few seconds. On my new EOS R, it is on continuously, which will wear it out a lot faster. Is there a quick fix for this?
22 REPLIES 22
Yeah I get it. The great thing is the quality of the sensor. You can push the hell out of the ISO and still get high quality images with fast shutter speeds. Good luck with it and most of all have fun.
"I do know is that constant IS doesn't seem to be much of an issue as far as battery power."
I really don't think you have to worry about it at all.  Just enjoy it.  If it should fail because of not shutting off. its just a lens and can be repaired or replaced.  The Sun will still come up in the morning.  Smiley Happy
If you have the EF 100-400mm L IS USM II there is a third position on the image stabilzation switch that turns the IS off EXCEPT during exposure. I am waiting for my 100-400mm to arrive. My understanding that turning this to position 3 also helps AF to operate faster. Just a thought.
Enter for a chance to win!
April 20th-28th
