EOS M50 clean HDMI output?
Snikkeren
Hi.
New member here. I got my M50 some weeks ago. I'm trying to set it up for live streaming, but I need a clean HDMI output to do that. I've managed to get an almost clean output, but I still get the focus box around my face. Is there a way to turn that box off?
19 REPLIES 19
Waddizzle
Negative.  First and foremost the M50 is a stills camera, not a camcorder or video camera.
Well, I actually just figured it out. All I have to do is set it to manual focus, and the focus box dissapears. As long as I'm sitting in about the same spot while live-streaming, I should be fine. If don't use too large aperture, I can stay in focus for normal movement while sitting in my "studio". I'm thinking about f4 to f5. 🙂
The HDMI output is probably a duplicate of what you would see on the LCD.  In fact, I would bet that the camera reroutes the video signal to the LCD to the HDMI port whenever it detects something is plugged into it.
Yes, the LCD shuts off when you connect the HDMI cable.
pauldumbravanu
I have the same problem. I try to stream but no sound. Streaming is made between camera - Avio 4k hdmi video capture device and youtube. No sound at all. Any clue?
Same issue. Hpw do you get sound out through hdmi?
You can't get the audio through the HDMI, you'll need to connect your microphone to your computer and bring it into your streaming software as an audio source. Hope that helps.
Dreampool
I’m using Blackmagic Webpresenter to live stream with my M50. How do I switch the camera to send the audio down the HDMI cable? I’m not getting any audio into the Webpresenter. I get vision fine.
kvbarkley
VIP
VIP
You can’t. HDMI sound is muted during recording to prevent feedback
