12-30-2020 12:53 PM
New to the EOS M50 used to have a different Canon Camera. I have movies recorded on my camera. I can play the files just fine from my camera. But then when I put the San Disk into my Mac computer (latest operating system) I can not play the videos. If I click on one file it is black then if I click on a second file it says quick time can not play. Then what is really odd is all the files just disappear from the San Disk all together after that error message. When I put it back in my camera they are all still there and working fine.
I have gone through is cycle multiple times. Each time I have black footage then get the error message and then all the files disappear.
Any ideas?
12-30-2020 01:52 PM
@mordesigns wrote:New to the EOS M50 used to have a different Canon Camera. I have movies recorded on my camera. I can play the files just fine from my camera. But then when I put the San Disk into my Mac computer (latest operating system) I can not play the videos.
Any ideas?
I'm not sure what media player you are using on your Mac, but you might try VLC Media Player. It's free and open source.
Steve Thomas
12-30-2020 02:11 PM
Have you tried to import with iMovie?
Another possiblity is that the "files" are actually packages and the video files are contained inside. Let me explain...
When you insert your SD card into your Mac, what is the folder structure on the card? Often times, you have to dig in a little to get at the actual media files.
For example, for an older Canon camcorder, there was a PRIVATE folder and within that, an AVCHD "file". But this was actually a package (macOS treats certain types of folders as packages which look like just a single file). So right-click (or Control-click) on AVCHD and select "Show Package Contents". In this current example, that revealed other folders and another "file" named "BDMV". Right-click on that to reveal yet another set of folders and files. Finally, there was a STREAM folder with all the individual .MTS files representing the clips.
These particular .MTS files have opened up a-ok for me over the years. Up to and including macOS 11 Big Sur. I used the QuickTime Player application.
