11-23-2020 06:51 AM - last edited on 01-26-2023 08:20 AM by Danny
Hi I have Eos M3 and I tried to use external mic BOYA M1 but i can not seems to record my voice. do you think this mic is not comparable or do i need special setup for mic?
I tried to use earphone + mic one too but this doesn't work either...
I would like to have clip-on the microphone if its possible...
If you can help me set up tat would be really appreciated...
Thank you
Sahori
11-23-2020 09:55 AM
I have an M3, but have never really tried to use it for any serious video. It has an external mic input, but no headphone output. So, I would not try to connect earphones or headphones to the camera because you could damage it.
I am not familiar with your microphone, but it does require an internal battery. I am sure you would need to go into the camera menus to switch the camera from using the internal microphone to an external one.
Download the User Manual from Canon Support, here.
01-26-2023 04:41 AM
January 26, 2023
I have the same problem too!
Same Canon EOS M3. Same Boya M1.
Were you able to find the solution after all these years?
