Reply
Highlighted
Occasional Contributor
EOS 77D
In the last year, I have had 4 photos appear as totally white with no details. The photos before and after are fine. Any ideas what might be causing this? Have a month before the warranty runs out.
Highlighted
Honored Contributor
Re: EOS 77D
From the rather sketchy information provided, a sticky shutter blade is probably the best guess. Call Canon and see if they have a better idea. If they don't, send it in before the warranty expires.
Bob
Highlighted
Re: EOS 77D
It has happened with 3 different lenses and I have contacted Canon.
Highlighted
VIP
Re: EOS 77D
I cannot rule out a mechanical issue. But, I suspect a more likely causes is user error. Have you compared exposure settings between good and bad images?
A mechanical failures are usually gradual, or sudden and complete. A completely white image sounds like a complete, non-recoverable failure to me. Except, your camera works properly 99% of the time.
What metering mode are you using? Which AF point and AF mode are you using? Does the EXIF indicate an exposure lock?
Highlighted
Re: EOS 77D
I took 3 photos at the exact same settings....only one was white.
Highlighted
Esteemed Contributor
Re: EOS 77D
We have had others complain about this, but I do not recall any solution.
Is all the exif data the same?
Highlighted
Re: EOS 77D
Yes...all the same.
Highlighted
VIP
Re: EOS 77D
@tomj63 wrote:
Yes...all the same.
Can post sample photos with the EXIF, one good and one bad?
Highlighted
VIP
Re: EOS 77D
"...  and I have contacted Canon."
What did they say?  I think you need to be communicating with them, not this forum.
Highlighted
Re: EOS 77D
I am communicating with Canon. Just thought I'd ask here in case some experienced something similar.
powered by Lithium
