Reply
New Contributor
EOS 6d won't power down
Hi all,
My EOS 6d seems to have a problem. Now and then, when I turn off the camera with the power switch, the screen stays on (but frozen). Camera is then not responding to anything. When I remove the battery and insert it again, everything is fine again.
Any thoughts on what the problem is? I already set it back to factory settings in the menu and updated the firmware.
VIP
Re: EOS 6d won't power down
Call Canon 1 (800) 652-2666
EOS 1DX and 1D Mk IV, even less and less other stuff.
Reputable Contributor
[ Edited ]
Do you see a Sensor Cleaning message or does it freeze immediately when powered off?
Are you certain of the quality of the battery?  Does it happen with other batteries?
Has the camera ever gotten wet, or been subjected to high humidity?
Have you done any firmware updates to the camera?
Resetting was a good idea.
Two ways to go.
Best way: Send to Canon for evaluation and repair
Optional steps:
Try a fresh (new) battery (may or may not help) not likely to help though
If you are one or more FW versions behind, you can try to update it. (Poses some risk)
In the end, Servce is usually the best option
Rick
~6D2 (f/w 1.0.4) ~16-35mm f2.8L II, 50 f1.8 STM, 85 prime USM, 70-200 f2.8L IS II ~70-300 USM II ~Sigma 24-70 f2.8 Art (f/w 2.02)
~Sigma 150-600 C + TC1401 1.4x (f/w 2.00) ~Speedlite 430 EX II ~DxO PhotoLab Elite ~Windows10 Pro1903 ~nVidia GPU
Honored Contributor
@Johannes1979 wrote:
Hi all,
Try it body only.  Remove the memory card, and any lens, flash, etc.   Does the problem persist?  If so, contact Canon Support.
powered by Lithium
