03-27-2021 09:08 PM
I've only recently encountered this issue today, where when I record video, no audio can be heard in the playback. It doesn't seem to matter if I use the in-body or an external shotgun microphone either. I know it's not a playback volume thing, cause even when I play the footage on my computer I hear no sound. Has anyone else had this problem and knows how to fix it?
03-28-2021 08:12 AM - edited 03-28-2021 08:14 AM
A little back story would be helpful.
New camera, used, or new to you?
Are you connecting anything else to the camera?
What kind of MIC are you using? (model) Is it powered?
Start here:
Test with one or two memory cards
Format them in the camera
Capture one or more clips, no MIC
Test playback?
Try with a second card if the first fails.
If it still doesn't work, reset the camera to defaults
Once again retest video capture and playback
If it still doesn't work, the camera will need to be inspected by Canon.
Canon U.S.A., Inc. | Service Request
~CarePaks Are Worth It
03-28-2021 02:06 PM
Hi Rick,
This is a new camera that I got for school around September 2020. The mics I were using were both the in-body and a cheap Takstar SGC-598, which draws power directly from the camera via jack. Still no playback audio can be heard no matter which mic I use. The camera has recorded audio previously that could be heard in playback, this is only a recent issue I encountered just yesterday.
I've tried your suggestions by recording and playing back on multiple cards with no success, and even resetting the camera settings did nothing to fix the issue. I'm afraid inspection may be the only option... and during my finals too... what a time to break on me.
03-28-2021 03:58 PM
You might be able to get it fixed under waranty, call Canon.
But til then get a zoom or similar recorder and add the audio in post. Just make sure to clap your hands or do something else to get a visual clue to synchronize the sound, like a clapboard
