Reply
Highlighted
Occasional Contributor
Accepted Solution
EOS 6D Mark II Web Registration
Hi guys,
I've just upgraded from a 70D to a 6D Mark II. I had the Wi-Fi working on the 70D and its comes up as registered on Canon Image Gateway.
I can't get the 6D to register (I can connect to the PC and upload pictures) but when I run the EOS Utility and use the Web Service Registration Tool I get the message "Failed to connect to the server" (I've got a very fast Internet connection by the way).
Any ideas what the problem is?
Thanks,
Charles
Highlighted
VIP
Re: EOS 6D Mark II Web Registration
@Charles2017 wrote:
Hi guys,
Thanks,
Charles
The most likely cause is problems with the web site.  I have never used the Image Gateway.  I shoot RAW nearly all of the time.
Highlighted
Hi Charles2017,
As Waddizzle mentioned there could have been a temporary issue with the website causing the message you indicated. If you continue to receive the message there are a couple of steps I recommend.
I would go to the software page for your 6D Mark II (HERE) and install the latest version of EOS Utility listed for your computer's operating system (should be ver. 3.8.20).
Once the latest EOS Utility has been installed login to the Canon Image Gateway site (HERE). When your account homepage loads look for the "Add new Wi-Fi products" section. Click the option for adding a new product, and follow the instructions on the next page.
Highlighted
Hi, I have V3.8.20 still the same "Failed to connect to Server" message.
Highlighted
Sorted! It is actually region dependent, In my Canon ID I changed my country to Hong Kong, registered the camera and changed back to UK. I now get 2 Image Gateways, one for EMEA and the other for Asia, double the storage capacity!
Highlighted
New Contributor
I was veeeery happy to see that Canon still supports a almost 10 year old camera. The new image.canon-storage-option is supposed to work with my beloved 6D, too.
BUT I do get the same error message, no matter how I delete the camera from my Canon-accound and add it while changing to another country. Does anyone else has an idea on what to do?
The camera was bought in the United States, but I guess / hope that does not matter much?
Thanks for your help!
Highlighted
Moderator
The EOS Utility is having issues updating the certificate for most EOS cameras right now. Bear with us while we work out the kinks rolling out the new service, please.
Highlighted
New Contributor
Great, thank you for the feedback, then I'll keep my legs still until further notice.
Highlighted
Now it's image.canon I can only login to one of the regions so I now can't access some of my pictures.
Highlighted
New Contributor
I have the same issue with my EOS 6D. Can you please let us know when this issue will be solved?
powered by Lithium
