Reply
Valued Contributor
Re: EOS 5D Mark II seems to have grainy images?
Just wanted to make sure we weren't chasing our tail trying to solve this.
You're right... ISO 800 probably isn't high enough to make much or any difference. A camera reset would be a good place to start. And when you're doing your RAW conversions turn off any sharpening and see if that makes any improvement. Have you tried to do any of your RAW processing in Canon DPP4?
VIP
“Image Width {0xA002} = 585 pixels
Image Height {0xA003} = 726 pixels”
No aperture data and a 50mm focal length is pretty normal for a lens that does not talk to the camera.  But, that is a pretty tight crop for a 21MP camera.  How can you be sure that what you are seeing is not just simply noise?
Occasional Contributor
I will upload a RAW file from the same shoot when I get to my camera tomorrow. That might be the best way to analyze it and see where the problem lies. Seems like this one and the original post are rare cases of soft and grainy images from the 5D Mk II.
[ Edited ]
Here is a link to the RAW image I shot to troubleshoot the softness and noise issue:
https://drive.google.com/file/d/1ntQgG3pnYoYhkCl3-73kmi_hFeg5uiz4/view?usp=sharing
The pertinent info are: Takumar S-M-C 28mm f/3.5, shot at f/8, 1/100 sec, ISO 800, tripod mounted camera. This vintage lens is known to be quite sharp at f/5.6 and f/8.
Reputable Contributor
[ Edited ]
Not strange you get noise in the image, check the raw histogram. Then pattern you showed in the print screen before seems to be due to NR and sharpening.
[ Edited ]
Thanks, Peter. Could the sharpening be accentuating the noise that's already in the RAW file? I don't believe I had cranked up the sharpening in ACR that high. If you look at the pale colored brush in the lower right, you will notice it is very noisy even in the RAW file (and has ample chromatic aberration), which is getting amplified in the post processed image by just lifting the gain up. It's a curve adjustment that is making the noise visible. Is that normal in the 5D Mk II at ISO 800? Also, given the exposure settings, nothing seems to be in focus. Would you agree? I am trying to be sure the problem is not in my particular camera sensor.
[ Edited ]
Lower right is really underexposed. It doesn't have to do to ISO 800. I can't see something wrong with your sensor.
About the focus it is hard to tell. Seems you have put the focus closer to you than to the subject.
powered by Lithium
