04-19-2014 10:32 AM
My camera is no longer turning on. I have tried switching between two fully charged batteries and nothing. I have also tried plugin it into the laptop and its not registering any device, or even the fact that there is a SD card. I have also re-installed the set up disk that came in the box, allong with running the trouble shooting cd that was in there, which just uninstalled everything that had just been installed on there. Any ideas?
04-19-2014 02:02 PM
There are two micro switches which can prevent the camera from powering up if they are not engaged.
One is on the memory card door. The other is on the battery door.
Inspect both... there's a tiny tab on each of these doors that presses the switch when the door is closed. Make sure neither the tab nor switch are damaged.
There are other micro-switches on the camera but these are the only two that will preven the camera from powering up.
If both of those are fine then you'll need to contact Canon.
04-19-2014 04:06 PM
Your a Star. Im thinking that there is something wring with the battery one, as i have pushed with more force on the battery than i would do and it has seemed to do the trick. Cheers for that
