Reply
New Contributor
Does the M50 support external stereo microphones?
I would like to know if I can plug a binaural microphone (3dio ) directly into the m50 without the need
for an audio interface. There is nothing in the manual that says that this camera has a preamp and also
supports external stereomicrophone.
I'm hoping someone knows the answer to this question. I want to record ASMR videos and want to use a 3dio FS plugged
into EOS M50.
Re: Does the M50 support external stereo microphones?
Hi there,
The EOS M50 does record stereo audio internally so it should also be able to acept a stereo signal through the microphone input as well. Canon's external stereo microphones like the DM-E1 and DM-E1D are listed as compatible accessories for the camera as well.
New Contributor
Do you know if the m50 also has a preamp? There is no information about this feature .
It would also need a preamp for a direct connection into it. Otherwise, an audio interface is needed.
Esteemed Contributor
It has a pre-amp since it does *not* take line level.  However, most mics have preamps in them already - they use a battery. Any mic designed for a video camera will work
powered by Lithium
