12-19-2018 10:26 AM
12-19-2018 10:23 PM
Thank you so much for the link and your reply with good information. I have read many articles and watched YouTube video's. I will admit the AF tracking system has me still trying to figure it out. I will read the link you provided and hopefully get to where it makes sense to me. If the lighting is good - the shots are coming out pretty good. But when the weather is very cloudy and gray - the subjects are fuzzy and grainy. Thankfully the 5D IV is much better than my 5D iii in the grain/noise.
Thank you
12-19-2018 11:04 PM
Quick question - I have both the 5D Mark III and Mark IV. When I was setting up the AF settings for the IV - there seemed to be a few different options. The guidebook you provide the link for - is there one available for the Mark IV or are they the same? Thank you
12-21-2018 05:02 PM
@Sadie1 wrote:Quick question - I have both the 5D Mark III and Mark IV. When I was setting up the AF settings for the IV - there seemed to be a few different options. The guidebook you provide the link for - is there one available for the Mark IV or are they the same? Thank you
I do not know. There is one for the 7D2 and the 1Dx II, both of which have AF systems that are similar to the 5D4.
12-21-2018 05:06 PM
Thank you
12-19-2018 01:31 PM
12-19-2018 03:29 PM
12-19-2018 04:03 PM
From page ~400 of the manual:
This is arguably better for your purposes than knowing the focus distance.
Your lenses should provide the distance info.
12-19-2018 10:13 PM
Thank you. I have that set up on my 5D Mark iii - but on the Mark IV - "Disable Display" is showing off and when I hit the set button to change it - it does not give me the option.
12-19-2018 07:05 PM
Great camara and great lens. When I try to shoot wildlife I use the top wheel to select the focus point but often have to anticipate. I pick the wildlife or an item at the same distance and lock the lens focus (hold at half press) and then compose/try to catch the animal befor pressing the rest of the way. Usually works.
12-19-2018 10:14 PM
Thank you - I am fairly new to wildlife photography and still struggle with it when the lighting is bad. I have not tried focus lock yet. Thanks
