12-04-2015 08:49 PM
I AM NEW TO THE DSLR WORD BUT AM WANTING TO PURCHASE AN UPPER END MID-RANGE DSLR FIR USE DURING MY HUNTING/FISHING EXCURSIONS WHICH AT TIMES MAY BE FRIGID, COLD, RAINY OR ALL OF THE ABOVE. CAN ANYONE RECOMMEND A CANON MODEL TO FIT THE BILL?
12-05-2015 10:32 AM
Yeah, no doubt, based on what you said you need. 7d Mk. 2.
Consider going body-only instead of buying a package deal with a kit lens if you can afford to get a good "L" lens, as most of them are weatherproofed, and It makes sense to keep the whole setup weatherproofed.
12-06-2015 09:19 AM
A nice feature of the 7D Mk II is its ability to use just about any 'alphabet" lens out there. It will not use one of the few and unlikely yo encounter EF-M lenses.
The letters are usually a naming scheme that the advertising department came up with. You really need to set a goal or a requirement standard before you go lens shopping. Other words, what do you want to take pictures of? Under what conditions?
A couple things to keep in mind, one is, weather-proof is a somewhat misleading term. Neither the 7D2 nor the lens is water-proof ! Splash proof is a better term. Secondly DSLR's like the 7D2, do need some consideration when you are in colder weather. Maybe 30 degrees and below. Batteries don't last nearly as long.
My suggestion as a pretty good starting point is the 7D Mk II and the Canon EF-S 17-55mm f/2.8 IS USM Lens. This lens is not a whole lot better than the standard kit lens but it offers a fixed f2.8 aperture which is a big plus. No EF-S lens is really weather-proof but this one has some attempts at it. Never-the-less this would be a great starter combo.
12-06-2015 09:10 AM
12-06-2015 11:34 AM
The 70D (a mid-range body) is weather sealed. The 7D II (a very high-end mid-range body and some might argue is weather sealed AND built like a tank. None of the Rebel bodies (these are entry-range bodies with price tags that start below $1000) are weather-sealed.
How durable are they?
Here's a YouTube video showing deliberate abuse being unleashed on a Canon 7D. They start out with some gentle knocks and then start ratcheting up the abuse level... freezing it in water, then shooting at it to break it out of the ice, then set it on fire and in the end... though it clearly looks like it's been through war... it actually still works! They did destroy the LCD screen (a part Canon service can replace.)
https://www.youtube.com/watch?v=RCT-YMgjm9k
Many (probably most) of Canon's "L" series lenses are weather sealed. But you need to specifically read the information in each lens to know. Also... some lenses require that you add a clear filter to the front of the lens to "complete" the weather seal. You'll know the lens is an "L" series lens because the name will put the capital letter "L" (in red) immediately following the focal ratio. E.g. EF 70-200mm f/2.8L IS USM II. Visually when you look at the lens it will have a red stripe around the front of it. Only Canon does this... you'll find 3rd party lenses that sometimes use a red stripe but it doesn't mean anything (those would not be "L" series lenses nor would they be weather sealed.)
The weather-seal treatment means that the body has gaskets and/or o-rings on all the various body seams and dials. These are sufficient to keep out water and dust as long it isn't under pressure or velocity (force). In other words, getting caught in a normal rain, getting splashed by a sprinkler, and dust isn't going to hurt it. Capsizing in a kayak and dunking it into a lake, river, pool, etc. very well might hurt it (astonishingly, a lot of 7D bodies have even had this happen and after a few days to dry out the camera was fine -- but it is beyond what Canon considers the limits of their weather sealed treatment.)
Also, don't remove the lens or open the battery or memory compartment door until you towel off any moisture, dirt, etc. becaues you don't want it getting into the camera body.
If you expect to be out in more aggressive foul weather then you might want to invest in a rain jacket for the camera. Since you specifically mentioned hunting... you might want to look up lenscoat.com who make protective coatings (in camoflauge designs) as well as rain-covers (they have "arm" holes to let you get your hands inside to control the camera and it could be coming down in buckets and the camera would be safe.) There are lots of companies that make rain-sleeves or rain-covers... mine is by ThinkTank Photo -- but I would nudge you in the direction of LensCoat only because they're the ones that make them in camoflauge patterns.
