09-24-2017 02:14 PM
Hello all
I'm the new proud owner of this camera model, but when I look at the exif data, the first owner's name is written 😞
Anybody have an idea, a fix or some possible way to change that, besides buying a new PC and find a win XP ?
Thank you
Soren
09-24-2017 02:26 PM
IF you got the CD with the camera you need both an older computer running XP or an earlier version of Windows PLUS you need a firewire port & cable. Communicating with that camera (I still own & use mine) is done via Firewire not through a USB cable.
09-25-2017 04:22 PM
09-25-2017 03:43 PM
Depending on which EXIF field it is, you might try setting the copyright information from the camera menu.
09-25-2017 04:23 PM
09-26-2017 02:21 PM
Sorry, I misspoke. It looks like that camera can't set the copyright from the menus, you have to use a computer. I just figured that if a Rebel could do it...
09-26-2017 02:44 PM
This has come up many times over the last few years & to date no one has found a way to by pass having to do it via Firewire. The good news is (going from memory) that you don't need the specific CD for the camera because the software disc for all the DSLR's of the era included it. 20D thru 40D & the 5D, 1D, 1D2, 1D2n, 1Ds & 1Ds2 seem to have the right version of EOS Utility.
