12-14-2020 01:03 AM
There seems to be a bright overexposure running along one edge of my photos, seems to be the bottom of the censor maybe. Anyone else experience this? I am using a Canon EF adaptor and a Sigma 35mm lens.
12-15-2020 04:24 PM - edited 12-15-2020 04:26 PM
I was using HSS flash. This is not a high speed sync flash issue. That image stripe on the edge is there whether its 1/300 or 1/800 which were most of my shots. The sync issue would be MUCH more prononced and in different location based on shutter speed.
Also, as I mentioned, its not there in mechanical shutter.
12-15-2020 04:58 PM
@bolofoto wrote:I was using HSS flash. This is not a high speed sync flash issue. That image stripe on the edge is there whether its 1/300 or 1/800 which were most of my shots. The sync issue would be MUCH more prononced and in different location based on shutter speed.
Exactly. Use the mechanical shutter. What's the point of using salient shutter with flashes and strobes popping off?
12-15-2020 02:13 AM
I have seen this before with the EOS R. Why it happened I never figured out, but randomly some images would have an oddly bright edge similar to this, always on the right/bottom edge. Haven't noticed it on the R5. It could be lens related, you never know. I would try a Canon lens if you have one.
